Originally Posted by MonoNeuron Oh, I forgot. Are you cutting fast enough?
If your not then you may need to speed up the cutting as this also helps to reduce the flaming. |
yes, i think the nozzle hole is too big, i ll try a reduction and test diference pressures.
ths for hints m8s
