Old 10-24-2004, 05:51 PM
squarewave squarewave is offline
squarewave is on a distinguished road
If you are referring to setting the coordinate system to your part, it is done with a G92. For example, if your program assumes the edge of your part is at X40.00, you would touch the X edge of your part with an edgefinder in the spindle, then do an MDI command G92 X40.00 (actually you would correct to the center of the spindle, otherwise you will be off by the radius of the edgefinder). You do the same again for Y and Z and then you have "picked up" your part. These have now established the "work" coordinate system, and it won't change unless you issue another G92.
