We have a default configuration which has all the tools that are regularly installed in the 2 VMCs. Recently the designers have been sending us parts that are exact scaled versions of parts we are already making. What I want to know is; is there any way to save the processes along with the tools so that we can just select new geometry from the scaled dxf file and not have to re-type in all the parameters for each tool/ process (DOC, speeds etc.)? We machine a large number of different parts from 3” X .5” 360 brass flat. I almost always use the same tools with the same process and it would be useful to be able to have a default configuration that I can just boot into, load and select the new geometry, hit “Do it” and post.
thanks |
