Thread: Problem Turned diameter is wrong.
Old 10-08-2008, 11:56 AM
jhowelb jhowelb is offline
jhowelb is an unknown quantity at this point
X0 should be the center of the part regardless of diam. or rad. mode.
In diam. mode when the tool is at center and you do "G0X25" the tool should move 12.5 increments because you are referencing the diameter of the part.
In rad. mode you must do your own math after measuring the diameter of the part.
I can't even guess why a tool would go to the rear radius for X zero.
"Error of Opinion may be tolerated where Reason is left free to combat it." - Thomas Jefferson
