Old 10-07-2008, 05:19 PM
kawazuki kawazuki is offline
kawazuki is on a distinguished road
Easiest way to elliminate the coupling is undo one of the grub screws and put some squeeze pressure on and re-tighten. Or take apart and ooze some silicone mastic on all the faces, re-assemble, leave to go off and you should have a flex joint without slop?
Thrust bearings does sound a good culprit though!
