Old 10-07-2008, 08:56 AM
Jay C Jay C is offline
Jay C is on a distinguished road
Originally Posted by MrWild View Post
The slop talked about isn't the slop you have. Ifyou redid the ball nut, the problem could be in your thrust bearings.
I suppose, but why do you say it's there an not in the coupling?
Also, the thrust bearings I'm using are the ones that come on the X2 originally ... they are being reused. Just simple ball cage sandwiched between two steel races seen here. There are two bearing actually. one on the inside, one on the outside. The outside one is held in place with a clamp collar.
Jay
