Old 10-06-2008, 10:58 AM
Roswell28 Roswell28 is offline
Roswell28 is on a distinguished road
The problem is that the machine is death, it does not let me to run the water thru the resin tank.
I can move all the axis, but when i try to turn on the fluid the alarm appears and nothing else happens...
Also the machine does not let me to threat the wire or cut the wire.
The water pump is good, we check it but it seams to me that some signal is missing, we try to turn off all the machine to see if it works but nothing happened.
Thanks...
