I decided it was time to rebuild the x and z axis on my lathe. I found that I have metric acme lead screws. Is this common on import machines? They look to be 12/3 or 14/3 on the x axis and 16/3(?) on the z axis. The nuts are made of either brass or bronze? My biggest problem/question is do I use the metric lead screws and buy metric acme taps for this project or try to make new ones using american pitch threaded rod? Second question what do I use for the lead screw nuts? I have some brass and oil impregnated bronze, but I don't know which will hold up better. |
