SRT
Associative machining it where the actual machining task is linked to the geometry in the drawing. Therefore, when for example a circle that was previously used in a drilling operation is moved to a new location, all machining tasks that used that circle are updated as well. This means you don't have to redo any machining operations when you change the model. This feature is new to OneCNC...just made available in the XP product. The lower end OneCNC products do not have this feature that I am aware.
Since the Excalibur Shop Floor product is the same as the Full product except without 3D surface machining, you get all of the power and machining optimization found in the full product...including associative machining.
