I just received my Keling package for the Super X3 yesterday and just have a simple question about the diagram you posted. My motors have 8 wires. From what I can tell from the diagram, you are supposed to take the Blu/Wht wire and the Wht/Red wire from the stepper motor and connect BOTH to the A+ terminal on the driver. Is that correct? And then both the Blue and Red wires go to the A- terminal. And so on...
In other words, I am supposed to be connecting two wires from the motor to the driver as indicated in the diagram to A+, A-, B+, B-, right?
Thanks for your help.
Originally Posted by Mongkol Hi Mike,
I can help you.Pls see the wiring motor as attached file. I have some questions. Is your stepper motor unipolar or bipolar? 6 wires or 8 wires? 2 phase or not? 1.8 degrees or not?Pls informs your detail.If you want to ensure,Pls take a photo the wire of motor and the terminal of the driver.
I can help you
Mongkol |
