Active high or low stepper is drive dependant (high=motor winding on or low=motor winding on.).
If your home is actually on the switch you can put the logic in the LIMITS.FIL.
Anytime a limit or home switch is triggered the LIMITS.FIL is ran.
If your home is not on the switch you can use ISTHERE logic in the commands G00, G01, JOG.FIL, ect...
Darek |
