Old 10-21-2004, 06:45 AM
Bubba's Avatar
Bubba Bubba is online now
Bubba is on a distinguished road
Jon,
make SURE you have the direction and sense properly set up. This can be tricky and may take "playing" with. Use the "Ports display" F2 and try manually tripping the switch to verify that works (or use "Active Ports display" Alt F2). Then if you see activity there, play with the direction and sense settings in the ini.
It does work, as I have three axis working on home.
Bubba
