Ya, I guess the Dremel spindle bearings are a bit sloppy for precise work. The Proxxon is easier to mount and seems to have more controlled spindle bearings. I guess if you must use a Dremel then some problems are over-come, but I think possibly others are introduced. Did the author say how well it worked?
Phil
Originally Posted by Regnar The dremel spins the insert and not the mills spindle. Doesnt say the effect on the dremel itself but the author did have it mounted off to the side before and said that the dremel alone was not rigid enough for fine milling. |
