Old 10-01-2008, 06:59 PM
jamiedaugherty jamiedaugherty is offline
jamiedaugherty is on a distinguished road
Originally Posted by Bubba View Post
Jamie,
Some words to think about.
As for using the existing screws, "been there done that" and was VERY disappointed. It got so bad that my backlash exceeded .125" and finally I was able to "walk" the nut down the screw without even turning it. Also, if you think you are going to make round circles (g02 03) and not have problems, forget it. Part of the circle will be climb milling and it will make a big mess of the part, possibly break the tool etc. (Don't ask how I know:{(
Just some food for thought.
My mill is almost brand new, so the screws are still tight. I'm guessing that it will last a long time, by then maybe I'll update to ball screws. Circle interpolating should not be a problem with this machine. Keep in mind that I'm not going to try and make accurate holes. Profile tolerances of .005in+ at minimum, usually more on the order of .015in. For accurate work I'll run a boring bar down through the roughed out hole. Mostly I'm looking to make parts with intricate outside profiles. i'm currently sending this out to another guy and I want this machine to make prototypes and test parts.
