The problem that I'm running into is the finish toolpath on a circle does not create a perfect arc, instead it is a series of flat faces. I thought that this might be a preview resolution problem in order for it to run faster, but a quick test cut resulted in the same problem. Does anyone have any ideas or encountered the same problem?
Also, when performing 3D milling roughing is it possible to keep the tool down between Z levels? I was able to program this in the HSM module, but in the 3D milling toolpath I'm unable to get this to work.
Great forum by the way, hope to contribute!
Thanks |
