Old 09-27-2008, 02:20 PM
cadcamslawek cadcamslawek is offline
cadcamslawek is on a distinguished road
Dan
Originally Posted by dmauch View Post
You should have a 2K current setting resistor if you wired the motor for bipolar series. A 3K if wire half coil. I suspect that you have a 3K resistor which is why it is hot. Also what is your power supply voltage?
Hmm your acceleration sure seems high
Dan
Hi I do run it in half coil with 3K resistor it is getting very hot but runs
now problem is that is not repeating position (like G00 X.200 1 full turn of the motor shaft but is not, faster it runs bigger position error/gap from full 360 degrees.
power supply is 42V at 5A
Slawek
