Do you have the rev 3 G540 with the chargepump disable switch that was released after 9-22? If not you need to contact gecko drives because the charge pump was a requirement and as I recall emc doesn;t have charge pump pwm output. On the other hand if you do have newer G540 then make sure that your pc bios is set up for EPP. The newer rev3 have a switch to disable the charge pump and thus will work with non mach3 programs.
Dan Mauch
camtronics-cnc.com
the case for the G540 and stepper motors as well as servo and other stepper products.
Originally Posted by SpeedsCustom Ok, I have a very simple wiring set-up, Only thing wired is an E-Stop to Pin 10 and 12 on 540 and Power Supply: 11 and 12.
I can't seem to get it out from fault.
I'm not sure exactly what my EMC2 stepconf pins should be set, I have an idea. But don't know if it's right.
What is everyone using for the 540 and emc2?
-Jason |
