Originally Posted by Matt Berube I am a little confused...
1. How are you using "multiple finish passes" with surface finish contour operation ?
2. Are you sure you have a sufficient retract & clearance specified ? |
I copied the tool path the first time ...
I figured that was the problem ....
second time I just created a new one ....
I will look into the clearance and retract ...
I know with a single pass I didnt have a problem ...
