Old 09-26-2008, 09:11 AM
debadip.basu debadip.basu is offline
debadip.basu is on a distinguished road
Problem in FANUC Wire Cut Machine
Hi Everybody,
This is my first post,I am having problem in FANUC make Wire Cut machine of Model-P,
System-6M model -B
Machine works ok in manual mode,no problem in referencing also.
But in auto mode it works up to the blocks having G0 command.
After reading the G01 command in any block it stops at that point only.
Even sometimes it works in that block also.But mostly for few days it stops at that block where G01 is given.
Checked the parameters,found OK.Make memory clear operation and tried but same problem.
Need help !!!!!
Debadip
