Old 09-24-2008, 06:48 AM
Boots Boots is offline
Boots is on a distinguished road
There is none that I know of. If you want to make a countersinked hole then you have to use a bit with the proper angle. You will have to draw the "Cross section" of the tool and save it into your Tool Box as an User Defined Tool. Once you do that alphacam will use this drawing to give you proper visualization of the countersinked hole in the Simulation process. This is to ensure that you are going to proper depth so there will not be any guessing at the programming station. Hope this helps ya.
