Old 09-21-2008, 01:47 PM
NC Cams NC Cams is offline
NC Cams is on a distinguished road
shut machine off
First unplug the machine Kboard and plug in regular keyboard inside cabinet.
Reboot and exit to DOS once boo up finishes .
Run C:\DEFRAG.
Then run C:\SCANDISK
If SCANDISK finds/shows errors, you can have it fix them. If SCANDISK can not fix, you may need to replace HDD.
If by chance you have a new HDD that is not of BPT formatting, this could be your problem - BPT format is 504MB ONLY. Larger size format will NOT WORK!!!
When replacing HDD, you have to partition C: drive to 504MB ONLY. or else software will get scrambled as data is stored. You will have to reload software on new HDD from back up disks.
YOu do have B/U disks I hope.
