You could try hooking up a simple regulated air blast, it wont take much air to blow aluminum chips, also switch to carbide cutters, you may also be defeating the purpose using 1000rpm, that is very slow and may not throw the chips out of the way as well as a more appropriate rpm.You will find the carbide much better cutting. |
