Originally Posted by edoggy Steve-M,
Do you have any more specs on the spur gear and rack gear. (pressure angle, number of teeth, diameter, width etc.)
Thanks, |
Hi
There a std "1 MOD" gear form 20 degree Pa, the racks are 2 Mtrs long 15mm wide x 15mm high with a lot of teeth, the spur gears are 16 tooth with a pcd of 16mm and 8mm wide, this way hopefuly if a disaster happens to a rack I have a "second life" by turning it round at least untill I can get a replacement
