I have term 10 connected to supply ground strip. I opened Mach 3 ports and pins and found and enabled the charge pump fuction set it port # 1 I only have 1 and set pin # to 16 tried active low and active high restarting Mach each time and I still have a fault light anymore suggestions
BTW this is an exixting machine I had it running xylotex previously
__________________ Learn from the mistakes of others you can't afford to make them all yourself! |
