Originally Posted by sansbury With the bit hung that far past the holder you are probably going to see some tool flex regardless of tram. |
I can confirm that is the case with a brazed carbide tipped tool. When I tuck the tip as tight as I can to the body of the flycutter I get less flex, but still you are correct - it could indicate some degree of tram issue.
