For example, say you want two motors for your X axis. Set up one as the X axis, and the other as either the A, B, or C axis, Then in Mach, you slave the A, B, or C axis to the X axis. Whatever the X axis does, the other will do exactly the same.
__________________ Gerry
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
