Originally Posted by SScnc Right, that makes sense to use 3/4".
I have a couple more questions,
(1) I was just getting ready to mill the CNCFusion block as shown in the first post of this thread but my table only slides out about 1/8" past the front of the base. The Y ballscrew nut appears to be hitting the front of the slot in the base.
Did you guys have to remove some of the cast iron in order to keep this from happening ? |
Yes, I milled the end of the slot out almost to the inside edge of the front casting wall.
(2) When doing the column relocation with the new steel plate did you have to mill your X2 base in that area down flat ? |
Yes, I milled the whole area where the new plate fit in order to provide a nice flat mating surface.
Alan
