The first thing I would advise you to do is to read the documents that came with your controller. Secondly learn a little about series and parallel circuits.
Your steppers are probably 3 or 5 volt steppers and they are run on 7 to 10 times the voltage they are rated at.
I don't know why you are hooking up your board to pin 14 this makes no sense at all.
budP |
