Old 09-09-2008, 04:17 PM
hectorbach hectorbach is offline
hectorbach is on a distinguished road
Mori seiki memory issue
thanks gowthu, i really appreciate it.
two questions..!
If the battery life was ended for a long time and parameters were lost, how can I do to copy those parameters from another Mori seiki similar lathe..?
Second is, what is the reference position, shoudl i find it or should I need to know that reference is on manual..??
Originally Posted by gowthu View Post
hey
first change the battery in machine on condition. Don't change inpower ioff condition. data will be lost.
After changing the battery switch on the machine.
check the machine status.Then in jog/handle mode move the axis to reference position and make parameter 1815.4 - APZ parameter as 1. this makes reference position establisset in each axis.
Try this for each axis and set reference position.
Please note that Parameter 1815 there is APC and APZ.
#1815.5 APC - Position detection is absolute pulse coder
# 1815.4 APZ - Referecne position of Absolute pulse coder established.
