Old 09-09-2008, 02:48 PM
NL2000 NL2000 is offline
NL2000 is on a distinguished road
First off, you didn't state if you are using a CF card. It must be a CF card. Then pop it in your pc and format the card using the FAT file system. DO NOT use the FAT32 system.
Lastly make sure your I/O channel is set to 4 before inserting the card. You can do this from the settings screen or with parameter 20.
