Thread: cnc procedures
Old 09-08-2008, 07:13 AM
locost_cam locost_cam is offline
locost_cam is on a distinguished road
Originally Posted by mike hide View Post
Looking at parts cut by Joe for his machine to produce a radiused corner the bit goes past the vertices or will the bit only drive so that the corner ends up with a radius the same as the bit radius?
SheetCam will try to cut what you draw as closely as possible, within the physical limits of the machine and cutter. if you have a sharp inside corner you will end up with a radius equal to the cutter radius. If you have an inside corner with a radius greater than the cutter radius then the resultant radius will be as drawn.
If you need to create a recess for a sharp cornered part, SheetCam has an option in the 'cut path' tab called 'overcut corners'. This will cut into sharp inside corners to allow a sharp cornered part to fit.
