Old 09-08-2008, 01:52 AM
etzz etzz is offline
etzz is on a distinguished road
Thumbs up 2.5D first parts and hints
I ran my first parts on Madcam, and was very happy with the results. See pics below:
A couple of real time savers that I learned:
- Use the rhino trim function to create part tabs (profile milling along curve). When creating your part, draw a rectangle over the contour path to create your tab. Then trim the contour path. When creating the machine paths, omit the trimmed curve on the last z level. See pic below.
- To panelize multiple parts, you can simply cut n paste as many as you want. Madcam pastes the new functions into the same layer. So the tool sequence is preserved properly. All tools changes will work out (ie first tool makes all cuts to multiple images).
HTH,
Eric
