Can you enter G-Code directly into the Centroid? I have Mach 3 and a custom DIY control set up, to calibrate it I wrote a short program to run each axis back and forth a bunch of times. If you can get a simple program to work right, then you can rule out the machine and the control and see what's up with the CAM software.
I don't really monitor the board, so e-mail me if you need anything and I don't reply or someone else doesn't reply.
Thanks,
John
__________________ John Delaney
www.rwicooking.com |
