I went into DOS and did a scandisk & defrag and both were 100% OK. Checked CMOS and everything looks OK, floppy drive runs . I've been using a DOS 6.22 Boot Disk with utilities & Explorer/Discovery/V2XT-DX 2.30_4.54 w/MS DOS 6.22 Disk from EMI that is susposed to be for Hard Drive Recovery. I do not have ANY factory back up disks for this mill. I got this mill used so i'm not sure if it is the original Hard Drive, mill was ran without an air filter and coolent got inside the cabinet so the Hard Drive is dirty. When i went to remove it i seen that the screws were only halfway put in so i'm sure its been fulled with before. What is needed for a DOM setup? After turning mill on and off about 20 times it did come up ok but now won't again. .........Thanks Mike |
