Old 09-04-2008, 09:13 AM
mactec54 mactec54 is offline
mactec54 is on a distinguished road
Hi isaac338
You can use these end mills with the threaded end in regular collets the diameter are the
same as a normal end mill I use them all the time I used to have a clarkson autolock chuck they work great but are not needed you will find most of these cutters will be metric coming from England unless they are very old cutters & then they could be inch dia
The threads will not interfere with the regular collet as the thread is just below the shank size or somtimes the same size as the shank but never bigger than the shank
Mactec54
