I am drilling in Anodized Aluminum 0.156" holes using a porter cable (27500 R.P.M) with a feed rate of 7.5 on a CNC Router. The drill bit is 2 step ( 0.156" / 0.200" with 100 deg chamfer) made from 0.500" carbide wih TiN coating on it. The problems that I am facing are:
1. Aluminum chips Built-up into the flute of the drill bit
2. burs at the bottom of the holes.
3. R.P.M. is too high, this way the manufacturer set the feed and speed.
4.If I try to reduce the RPM the bit breaks from the 0.200" dia.
Can anyone help me in setting up these parameters to get an efficient and clean job done.
Thanks,
Kaleem
__________________ Kaleem |
