Old 09-03-2008, 07:00 AM
blmmdes blmmdes is offline
blmmdes is on a distinguished road
Yes Harold you can open a default post provided by UGS and save it as a copy after modifications. Once you hit Save in post builder it creates 3 files. *.pui, *.tcl and *.def. Unless you modify the tcl and def manually they are attached to that pui file.
Post builder came recently and its good.I agree it takes time to understand the menus. Otherwise people like me used to modify the posts through notepad only. That requires a bit knowledge of TCL as well. Creating a post in itself is a R&D work so trial and error are part and parcel of it.
I suggest you bigin with simple customization on post builder. Your requirement (adding M05, M01 M30 etc) also simple so get started with it. you can minimise(upto zero %) the manual intervention. you can always come back to this forum if have any questions.
Ananth Kulkarni
THE GREATEST OAK WAS ONCE A NUT WHO HELD ITS GROUND
