Hi Nabil,
Yes, I did use the translation option. I created a rectangle, then I created a toolpath and chained around the rectangle clockwise with cutter comp on the left (climb cutting). I then went to toolpaths ~ transform ~ translate and checked the box to create geometry and toolpaths ~ X 1.5 Y 2.0 X 4 Y2. When I run the toolpaths on the translated operations it is chained in the reverse (counterclockwise) direction and cutter comp is now on the right. |
