I use Dynatorch post processor, but sheetcam has a whole list of different PP including Dynatorch in there program that you can pick and choose from, wwwcncinformation.com is a guy named Ivan Irons,he has put together a bunch of different video's relating to cnc plasma,including sheetcam... you can also find him/them on youtube...sheetcam has its own tutorial, but i found watching the vids helped, i cant really compare sheetcam to anything else as its the only one i have used, but for a guy like me that runs diamond drills for a living, learning this program on the puter was relatively simple, but i did watch his video's half a dozen times before it really sank in. Any drawings i make or modify in corel, i export as .dxf into sheetcam, sheetcam spits them out as a .tap file, open .tap file in Dynatorch and it cuts the peice....once into Dynatorch it also can modify the file by sizing, rotating, nesting, etc... sheetcam also has a nesting feature and a bunch of other things that i cant think of at the moment, would be better if i were home and had it infront of me.
EDD |
