Old 10-08-2004, 03:46 PM
pminmo's Avatar
pminmo pminmo is offline
pminmo is on a distinguished road
Pigi,
First put power on the board without it hooked up to the pc or driver boards. LED1 should illuminte. Hopefully you saw the errata in the document and installed a jumper inplace of LED2 ? Assuming LED1 illuminates, LED7, LED9, LED10, and LED11 should not. If those verify, placing a jumper accross Xhome should illuminate LED9, placing a jumper accross Yhome should illuminate LED10, placing a jumper accross Zhome should illuminate LED11.
If all is well at that point jumper pad1 or JP4 pin2 to 5VDC pad, when you do that LEd7 should illuminate.
Phil
