A new step, here is my model that consists of different parts.
- White is the skin around the object that will need to be finished.
- Underneath the white is a blue object, which you can't see of course.
- The yellow is material that needs to be cut after finishing, so that the object get loose from the clamp.
- The red are the clamps, onto which the material is mounted and may not be worked on by the tool.
Around this will be material that needs to be roughed, it will be green, but then you wouldn't see the other parts. |
