Chris,
Many parts must be flipped over to machine the opposite side. Plan your job so that you can locate the second side on a fixture (or fixed stops). The surfaces you use to locate the second operation should be ones milled in the first operation.
Sometimes this can require milling some temporary surfaces that will be removed in later operation.
Bill |
