Old 10-06-2004, 11:10 PM
chrisgr chrisgr is offline
chrisgr is on a distinguished road
Elementary CNC Question
I want to get into CNC machining and I have some elementary questions:
A 3 axis CNC mill will obviously only mill a part from the top, with the stock material secured against the table in some way.
If I'm machining a part with a flat back, how do I machine all the way through in some areas so the part can be detached? I assume you leave tabs so the part remains held while machining and then cut them manually? But how do you machine through the edges with out hitting the table? Do you put some hopefully flat sacrificial material under the part?
I guess the other possibility is to turn over the part, carefully align it and mill from the other side. However this might be a waste of time if that side is flat. Also the previously milled face will not be flat, and would be difficult to secure in a level position.
I've searched the web for answers, and I find articles typically showing the machining the outline of a part from the top, but they don't answer the questions.
Any advice would be appreciated.
Also, is there a CNC book that starts with the basics?
- Chris
