You have probably already done this, but just to cover all bases:
1. Do you still have the chip guard switch connected? It could be faulty.
2. Have you checked the power supply fuse?
3. Have you checked the motor fuse?
Chances are though, that your quill DRO slide has shorted against the control PCB. Removing this is the first thing a new owner should do.
CR. |
