Normal wood routing uses 2 flute router bits. I will be using solid carbide 4 flute end mills with this machine. I not only want to machine wood, but metal as well. My shaper table in my wood shop only turns about 5000 RPM and has no problems with wood cutting in surface quality even on end grain.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
