What Fanuc control and what software are you using? also are you using hardware handshake or software HS?
Usually it is not a problem with pentium, although you could get hold of a Null modem cable and try that, that is if you have the Hardware HS jumpered out.
You can also try uploading using Hyperterminal (comes with windows) if the PC is windows based, if you can get a copy of Terminal that came with Win3.1 that works even better, it will also run under Later windows versions.
Al
__________________ CNC, Mechatronics Integration and Machine Design.
Albert E. |
