RS232 problem sending with newer PC | | Hello everyone
We have a Fanuc control connected with a 486 class PC for sending g-code over to the control.
Recently I swapped out the 486 class PC with a newer and much faster Pentium class PC. Ever since then I can not transmit from the newer PC to the control, I get an rs232 communications error each time. The PC can receive just fine. I've double checked my setup and all is the same. I've tried other PC's as well with no luck either. Things work great as long as I use any old 486 class or lower PC. It seems as if a Pentium class PC is to fast for the control. I've tried slowing down the com port and that does not help either.
Does anyone have any experiences with this type of issue? If so I would sure appreciate any advice for the next best thing to try.
Regards,
Jeff Norby |
