Thread: DOC?
  #12   Ban this user!
Old 08-19-2008, 12:48 AM
timmydabull timmydabull is offline
timmydabull is on a distinguished road
in the parameter page where you select the pocket depth there is a tab labeled DEPTH CUTS.
check the box and set your maximum depth of cut in the first box,you can select your finish cut in the second box.
this will prevent your endmill from taking 100 percent plunge to the depth of your pocket.
cheers
2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
