thanks for the reply
Is torque related to amps or volts? what I mean is lets say the motor is rated at 120 volts 20 amp and lets say that makes 670 oz/in of torque and spins the shaft at 1200rpm. Now if you reduce the volts to 80 but keep the amps at 20 are you gonna get more or less the same torque just at a lower rpm? |
