Well I just wanna say I'm not trying to sell the stuff, just wanted to pass along something that I found worked as advertised. I'm in the same boat as a lot of you I think in that without someone here to hold my hand I just try this and that untill I stumble upon something that works.
It's a really good feeling when I finally get it right. This stuff is still fresh after two months in the AZ heat in my garage getting used only on the weekends. Another nice thing about syn lube over the sol-oil stuff is that I can see the part while it is being cut. I can also see the bottom of my sump, makes knowing when to clean it a bit more than guess work, like it used to be.
In terms of coolant care I also added a coalescer, and ditched the wheel skimmer. Works much better, keeps the coolant moving 24 / 7, and full of oxygen. |
